Renames virtual networks.
| virtual-network | Configures virtual networks. |
| vn_name | Specifies the virtual network to be renamed. |
| name | Selects renaming the virtual network. |
| new_name | Specifies the new name for the virtual network. |
N/A.
Dynamically created virtual networks are not saved to the configuration. When a dynamically created virtual network is renamed, the virtual network becomes static and is saved to the configuration.
The following example changes the name of the virtual network from "vn1" to "vn2":
# configure virtual-network vn name vn2
This command was first available in ExtremeXOS 30.3.
This command is available on all Universal switches and stacks supported in this document.
